Bit lamp illuminated graphic in 0 state
Bit lamp illuminated graphic in 0 state https://forum.weintekusa.com/uploads/db0776/original/2X/3/36e1e422bc38272f124939b0c2bf5c9c586b585b.png
  • HMI Model: cMT2108x2
  • EasyBuilder Pro Version: v6.08.01.614 build #2023.08.28
  • Serial Number or supplier: 2204101524
I would like to do a graphic object of the bit lamp type that is illuminated red in the off/0 state and illuminated green in the on/1 state.
current 0 state is this:
current 1 state is this:
ideal 0 state is this:
pulling from the picture library doesn’t seem to allow the illuminated object in the 0 state
Forgive me for not using the same library but you should be able to just copy the states out of that library and paste them into your project library or your own library.
well… that’s easy!
thanks
