cMT2078X CODESYS Package 1.5.3.529 Installation Failure
System Information
HMI: Weintek cMT2078X
CODESYS Runtime Version: 20250926
Runtime Status: Start
License Status: Activated
Engineering PC:
Windows 11 64-bit
CODESYS V3.5 SP15 Patch 5 (64-bit)
Build: 3.5.15.50
Package:
CODESYS-and-RemoteIO-Package-1.5.3.529.package
Problem Summary
The cMT2078X runtime activates successfully, firmware updates successfully, and the target is detected by CODESYS. However, the Weintek CODESYS and Remote IO package cannot be installed completely because of a library compatibility conflict.
Installation Error
Package installation stops with:
Base_Itfs.compiled-library-v3
Interface library is not compatible to existing versions.
Checked against:
Base Interfaces, 3.5.2.0 (System)
Reason:
Function ‘real64__to__any64’ renamed or deleted
Current Repository State
Base Interfaces library installed:
Title: Base Interfaces
Version: 3.5.2.0
Company: System
C:\ProgramData\CODESYS\ManagedLibraries\System
Only one version of Base Interfaces exists in the repository.
Build Errors
After package installation, a new empty project created using either:
  • Weintek Built-in CODESYS
  • cMT-CTRL
    fails to compile.
    Common errors include:
    Could not open library:
  • IoStandard 3.5.10.0
  • CmpLog 3.5.5.0
  • CAA Types Extern 3.5.10.0
  • Component Manager 3.5.9.0
  • CmpApp 3.5.9.0
  • SysCpuHandling 3.5.8.0
  • CmpEventMgr 3.5.8.0
    and unresolved symbols:
  • IoConfigTaskMap
  • IoConfigParameter
  • IoConfigConnector
  • LogAdd2
  • CMAddComponent
  • SysCpuTestAndSet
  • CmpEventMgr.EventParam
    Additional Findings
The following libraries are already installed:
IoStandard 3.5.15.0
CmpLog 3.5.15.20
CAA Types Extern 3.5.13.0
Component Manager 3.5.13.0
CmpApp 3.5.15.0
SysCpuHandling 3.5.13.0
CmpEventMgr 3.5.14.0
The required types (IoConfigTaskMap, IoConfigParameter, IoConfigConnector) exist within IoStandard 3.5.15.0 but are not resolved during compilation.
Verification Performed
✓ Dashboard activation successful
✓ CODESYS license activation successful
✓ Runtime firmware updated from 20240703 to 20250926
✓ Runtime visible in Communication Settings
✓ Gateway communication working
✓ Target online and reachable
✓ Device descriptions installed
Request
Please confirm:
  1. Is CODESYS V3.5 SP15 Patch 5 (64-bit) the correct engineering version for Package 1.5.3.529?
  2. Is Base Interfaces 3.5.2.0 expected to remain installed?
  3. Is an additional prerequisite package required before installing Weintek CODESYS and Remote IO Package 1.5.3.529?
  4. Is there a newer or older package version recommended for cMT2078X Runtime 20250926?
  5. Can you provide the correct package/library combination needed to resolve the Base Interfaces conflict?
Hi @subpilot ,
Thank you for your question. Could you please attach screenshots of the issues you are experiencing?
Hi @subpilot,
    Yes.
    You should not need to install other libraries as long as the recommended version of CODESYS was completely installed. Per Arden’s request above, can you please provide a screenshot?
    No.
    You should use the install the latest package.
    We are not familiar with this issue, but are speculation is that the CODESYS development environment did not install correctly or completely. Can you please re-attempt install and make sure that the complete install is performed?
Hello, sorry for the delayed response. I was able to download the missing libraries from Weintek through Codesys Library Manager. I appreciate the effort!
