I have a system with a CMT2078X+CoDeSys and a system with an IR_ETN40R+ a temperature module. If I do a compilation, no errors are given, but when I try to do a download, the attached picture appears and the download doesn’t go through.
I’m working with Italian support but we can’t find a solution. Any ideas? (the panel’s operating system was updated a few days ago)
Hi @abmeccanica ,
Thank you for your question. Could you please confirm which version of CODESYS you are using? Additionally, are there any missing libraries reported in the Library Manager?
Hi. The project I was using started from modifying an old project. Now I tried creating a new one and the IR seems to respond. Thanks as always, and if I run into problems again, I’ll let you know.
