- HMI Model: MT8072iP
- EasyBuilder Pro Version: latest
Hi,
Background: I am trying to connect the above Weintek HMI to a BACnet/IP-capable controller - specifically a T3-BB controller from Temco Controls https://temcocontrols.com/ (Spokane, WA & Shanghai). I have a very simple system - 1 x HMI, 1 x controller and (during development) 1 x PC running both EasyBuilderPro and the Temco programming environment (T3000) - all connected via an Ethernet switch/LAN.
Following the Device Connection guide for BACnet/IP PLCs - and with a little experimentation - I successfully added a BACnet/IP device and connected to my controller. However the tag list did not populate correctly (Get tag info..)
The Temco controller uses three main tables which EasyBuilder needs to access:
- INPUTS. These are universal inputs, configured in software as digital or analog (multiple type/range options). My particular controller has 32 inputs - 13 analog and 17 digital (+2 spare). The table allows for 64 Inputs
- OUTPUTS: Table allows 64 outputs, but the controller has 12 digital and 12 analog outputs - mostly used.
- VARIABLES: Table allows 128 - configurable as digital or analog I expect to have about 30 analog and 80 digital variables.
The controller also has calendars and schedules but I dont use them.
These separate tables are for user presentation. All the config & data is held in about 1500 registers. A final screenshot shows part of the register covering 32 Inputs (values)
Problem: After I “Get tag info”, I see both types (Analog & Binary) of Outputs, and both types (A & B) of Variables, but I dont see ANY Inputs of either type.
I planned to attach screenshots (PNG files) of the Tag information and the controller Input table. However I was unable to - instead there was an error “Sorry, you cannot embed media items within a post.” This restriction makes things harder! Why is a PNG file considered media?
Curiously, EasyBuilder readily distinguished analog and binary items in the VARIABLES table, but did not see/distinguish analog and binary INPUTS.
What I should do to correctly populate the tag list with Inputs??
(I have asked Temco the same question)
I wonder if a possible solution might be to (use Excel to) create a special tag list as a .csv file and import that into Easybuilder. The required file format is described in the connection guide. Is this possible?
I presume the .csv file must use the exact same object name that appears in the corresponding controller tables (eg “Full label” (max 20char) or “short-label” (8char)) in order to link the HMI tag-list with controller inputs, outputs and variables.
Do I need to be fussy to match the “instance number” with the I/O/V sequence - eg Input numbers 1, 2, 3 are Instance numbers 1, 2, 3 ??
There are only 32 inputs anyway, but I could make a partial tag list .csv file to try the idea. What do you think?
