I have some I/O modules that I thought supported Modbus, but turns out they are Ethernet/IP only. I tgried configuring the Ethernet/IP scanner in Codesys, but it doesn’t compile when using the Weintek Device (249 errors). Is there a library or something I’m missing to make this work?
Does Codesys support Ethernet/IP?
Hi @jjansen,
It is possible to communicate with certain Ethernet/IP devices that use explicit messaging through Codesys. However, this requires Weintek USA’s Ethernet/IP library which is currently available by request. In general, Weintek’s built-in Codesys is not equipped with the Etherent/IP license that is required to utilize the libraries produced by GmbH. Therefore in order to communicate with an Ethernet/IP device using Codesys, I would recommend the following:
- Utilize the Ethernet/IP drivers available within EasyBuilder Pro:
- Follow the instructions within our “Weintek’s built-In Codesys to Modbus Gateway” document to route communication from Codesys to the external device.
Related subject - but just with HMI and no Codesys:
The EB Pro manual shows how to configure the HMI as a Modbus Server, can we setup the HMI as an Ethernet IP Server?
