Is there a purge instruction for the free protocol ethernet driver? The purge I see in the manual pertains to the serial port.
How do you purge an ethernet port?
Free Protocol Ethernet Driver Purge of Port
https://forum.weintekusa.com/uploads/db0776/original/2X/6/6ad56d65bf4ddb06132eaea10658e43e38be77af.png
Hi @SteveV,
There is no PURGE command for the Ethernet port, but it is possible to “clear” a set number of bytes by performing an INPORT into an unused variable. Here is an example:
sub ePurge()
char g[255]
short len = 0
INPORT(g[0], "Free Protocol Server (Ethernet)", 255, len)
end sub
char a[32]
short receive_len = 0
bool on = true, off = false
ePurge() // "clear" last 255 bytes of data on eth port
FILL(a[0], 0, 32)
DELAY(1000) // wait one second
INPORT(a[0], "Free Protocol Server (Ethernet)", 32, receive_len)
if receive_len > 0 then
SetData(a[0], "Local HMI", LW, 0, 32)
SetData(on, "Local HMI", LB, 0, 1)
end if
