HMI Model: MT8072iP
EasyBuilder Pro Version: V6.10.01.465
We are using the ODVA General Ethernet/IP (Implicit Messaging) driver to communicate with a scanner. The scanner requires a trigger signal: write a
1to its trigger word, then reset it back to0after a short time (a few hundred milliseconds).In EasyBuilder Pro, we created a Word Object to write a constant value. This works to set the trigger to
1, but there is no built-in option for a momentary pulse (automatically reset to0). The word value stays latched at1until manually written back to0.To solve this, we attempted to use a Macro to write
1to the scanner trigger, delay, then write0again. However, when compiling, the macro produces syntax errors when usingSetData()with the ODVA Ethernet/IP device name and Output_Byte address. We also tried variations (using the device name from System Parameters, device number, and IP address), but none compile successfully.What we need:
A supported method to generate a momentary pulse (set word = 1, delay, then reset = 0) to the scanner trigger word using the ODVA Ethernet/IP driver.
Clarification whether this is supported via Word Objects, Multi-State Switches, or Macro commands, and if so, what syntax or configuration should be used.
If this is not supported in the current version, please advise if there is a workaround or whether a newer version of EasyBuilder Pro / firmware adds this capability.
How to setup a momentary numeric value
Hi @meyer ,
Thank you for contributing to our forum and for the detailed post.
I recommend trying a Toggle Switch with the switch style set to momentary. You can also try a Combo Button paired with a Set Word that writes a constant value of 1, then add a delay, followed by writing a constant value of 0.
Please let me know if you have any questions!
Toggle Switch
Combo Button
