Macro case with multi-letter string
Is it possible to perform a case statement on a two letter char variable?
i.e.
case “AA”
case “AB”
Hi @jnorris,
Since the “case” within a select case statement must be a constant, it might be easier to compare a two character string using an if statement instead. Here is an example:
char aa[2] = "AA"
char bb[2] = "BB"
char ab[2] = "AB"
bool compare[10] = {0,0,0,0,0,0,0,0,0,0}
char in[2] = {0,0}
GetData(in[0], "Local HMI" LW, 0, 2) // Get data for testing
compare[0] = StringCompareNoCase(aa[0], in[0]) // compare input to "AA"
compare[1] = StringCompareNoCase(bb[0], in[0]) // compare input to "BB"
compare[2] = StringCompareNoCase(ab[0], in[0]) // compare input to "AB"
if compare[0] then
	// input == aa
else if compare[1] then
	// input == bb
else if compare[2] then
	// input == ab
end if
Awesome, thanks Brendon.
