How do I use cMT Viewer via port forwarding?
  • HMI Model: cMT-SVR-100
I’m having an issue accessing my HMI through CMT Viewer on separate networks. My HMI is behind a cellular router with a static IP address assigned by the ISP. I have port forwarding enabled based on some online documentation showing the default port # being 8000 so when I try to connect via ■■■.■■■.■■■.■■■:8000 I get a failed to connect. Thanks!
Using CMT-Viewer over Internet via port forwarding requires port 80, You also have to setting up the following ports on your router.
Got it, thanks!
