EasyBuilder Pro Version: V6.10.01 (User Manual)
Hello Team Weintek
In the spirit of constructive feedback, please see below and screenshots regarding memory limitations for declared variables in an EasyBuilderPro application, as documented in EBPro User Manual V6.10.01
Thank you also for responses to Questions 1-4.
p18-10 Declaring Arrays
p18-10 states that the length of an array could be 1 to 4096, then provides suggestive examples of int, short and float, but does not mention the 4096B limitation.
Issue: The 4096B limitation isn’t mentioned until 103 pages later on p18-113. (see next)
Consequence: The omission of limitation misleads User, who may not also read the interim 103 pages, only to discover this non-standard limitation the hard way after attempting code destined to fail.
p18-113 Macro Ref
States that the total size of data type that can be declared in a function is 4096B.
Q1: Does same limitation exist for global array declarations?
Q2: Is there a 4096B total-sum limitation for all variables in a given EasyBuilderPro application, including all variables declared both inside and outside functions?
Q3: What is the maximum total byte allocation for all variables, both local and global, in a given EasyBuilderPro application?
Q4: Is there a way to observe and/or monitor [percent,KB] consumption of available memory for variable allocations during code development and/or upon compile?
p18-118 Macro Notes
Section 18.10, Article 1 provides an outline of maximum array size according to different variable types per 4KB limitation.
Suggestion: Mention of this maximum array size outline or outline content could be included or linked on or in continuum with p18-10 Declaring Arrays, avoiding the 108 page separation of this valuable guidance regarding non-standard EBPro limitation.
