BACnet MS/TP Development Platform
- HMI Model: cMT-FHDX-220
- EasyBuilder Pro Version: V6.10.01.252
- Serial Number: 2204105895
Hello Team Weintek -
In developing a BACnet MS/TP system we have encountered a problem in object (tag) discovery.
The BACnet MS/TP system requires 63 total objects (tags) to be discovered.
Problem: The EBPro Tag Manager only discovers 50 objects (tags), does not discover the remaining 13 objects. This shortfall is reflected in the Tag Manager window and in the exported *.csv file.
YABE and Contemporary Controls BACnet Discovery Tool
All 63 tags are discovered by YABE (Yet Another BACnet Explorer) and Contemporary Controls BACnet Discovery Tool (BDT).
In addition, both YABE and BDT successfully obtain and display the object (tag) names, which are lacking in the Weintek Tag Manager interface and in the *.csv tag file. It would be helpful, perhaps in the future, if the object names could be accommodated.
Screenshots:
EasyBuilderPro System Parameter Settings
63-object (tag) YABE discovery
50-object (tag) Weintek Tag Manager discovery
Q: What might be the causative factor limiting Tag Manager discovery to 50 out of 63 objects for the Weintek system, in contrast to YABE and BDT successfully discovering 63/63 objects?
Thank you.
