The UIM342C device manual seems to indicate that the controller requires an initial input instruction before returning a ACK or reply. This is a bit different than the typical use case of our “CAN bus 2.0A/2.0B…” driver as we cannot define a custom packet using this driver. The driver only allows the use of predefined CAN Command registers such as in the example below:
Therefore, I will need to discuss this issue with my colleagues to determine if our software can be made to communicate with the device that you are using. Please standby and I will provide an update as soon as possible!
Unfortunately, we do not have a driver that is suitable for this custom implementation of CAN communication. Does this controller offer support another standard communication protocol by chance?
Also, we would like to know why this controller was chosen specifically so that we can understand it’s use case within your application and as opposed to other controllers with similar functionality. Note: This question is only for our internal case notes.
I see, in that case the cMT3072XP will not be able to communicate with this device as it requires a non-standard implementation of the CAN Bus protocol. I apologize for the inconvenience and appreciate your prompt response in answering our questions.
