- HMI Model: cMTx product line
- EasyBuilder Pro Version: V6.08.01.453
Is there a way to insert an entry into the recipe list? The [1] add new recipe record always adds it to the bottom, but A customer has a few dozen recipes, and if he adds a new one he would like to maintain alphabetic order.
Is there a way to insert above or perhaps sort alphabetically after the fact?
Thanks!
Hi @jjansen,
Unfortunately, it is not possible to “Insert” a record. However, the records can be resorted by clicking the column header of the “Recipe View” object. Here is an example:
- The records are displayed in alphabetical order:
- I have added a new record that is out of order:
- By clicking on the “Name” column header the records will be sorted in alphabetical order:
Also, if you configure the “Default sort method” within the properties of the “Recipe View” object, the recipe table should re-sort the list when adding a new record.
