Hi there, is there an update for MT8100ie HMI? I can’t connect it to and OPC Server and want to discard a Firmware issue. Thanks a lot =)
The HMI’s firmware does not effect communication as these rely on the driver files installed with EasyBuilder Pro.
We recommend you follow this connection guide from our forum to help you get started with setting up your HMI as an OPC UA client.
Can you please let us know if there is an issue with this unit or if there is a feature that you need to use which requires a specific OS?
