Can the HMI connect to EasyAccess 2.0 using LAN 2?
HMI Model: CMT307X
Hi I have the network settings to assign the IP address automatically.
I have connected my modem and a WIFI to Ethernet module I have to LAN PORT1 and I am able to see the unit online thru easy access.
But when I connect my modem directly to LAN PORT 2 I see it assigns an IP address my checking in the settings menu, but the HMI never appears online in EASY ACCESS.
Thanks
Hi @gary14,
The LAN-2 port of the cMT3072X cannot connect to the internet unless the HMI has an active Codesys license. By default, it should only be used for LAN communication. That is why LAN-2 does not allow you to configure a DNS or Gateway address, whereas LAN-1 does.
