Using an irETN40R unit in codesys, but having an issue with the configuration. Bus Cycle Task: ENIPScannerIoTask. Not sure if issue is related to settings or the IDE version. Priority is 2, with a cycle time of 20ms.
IDE: Codesys 3.5.21.0
Ethernet device version: 3.5.15.0
Ethernet/IP Scanner device version: 3.5.15.50
Possible to correct via mods to .eds file, library files, etc. or does this system only work on an older version of codesys?
Hi @edanish70,
We recommend using Codesys version 3.5.15.50 because our R&D team has tested this version extensively. A later version may be used but we cannot predict what issues may occur when using later instances. So, you may be correct, this issue may be caused by not using the recommended version of Codesys.
You could also try following the instructions in this forum post on using EIP within Codesys. It’s also possible that the the HMI’s Codesys firmware needs to be updated (instructions provided in the post).
