The CODESYS V3 Ethernet driver does not support encryption.
Regarding the issue with loading tags, I have attached a link to our CODESYS V3 connection guide. Could you please ensure that the settings in your project match the information outlined in the guide?
If you are still encountering errors during the tag import process, please send us screenshots of your setup so we can review it.
Thank you, and please let me know if you have any questions.
ctrlX PLC is communicating only encrypted since years.
Which version do you use? Can you please recheck.
I found this information about CODESYS:
Starting with CODESYS Runtime ≥ 3.5 SP14, encryption can be enabled to secure this communication — which is critical because, without it, credentials and process data could be sent in plain text.
How PLCHandler Encryption Works
Purpose: Protects authentication credentials and PLC data from interception or tampering.
Mechanism: Uses TLS (Transport Layer Security) for the communication channel between the PLCHandler client and the CODESYS runtime.
Configuration: Encryption is enforced via the Communication Policy in the runtime settings.
Steps to Enable Encryption for PLCHandler
Update Runtime
Ensure your CODESYS runtime is 3.5 SP14 or newer.
Enable Encryption in the PLC
Open the CODESYS Control device configuration in your project.
Navigate to: Device → Communication Settings → Communication Policy
Set Encryption to Required (or at least Preferred).
Deploy the updated configuration to the PLC.
Configure PLCHandler Client for Encryption
In your C/C++ application using the PLCHandler SDK:
Use the encrypted connection flag when calling PLCHandler_Connect().
Provide the TLS certificate if the PLC is using a self-signed or custom CA certificate.
Certificate Handling
If using a self-signed certificate, the client must trust it (import into OS trust store or specify via TLSCertFile).
For production, use a CA-signed certificate.
Test the Connection
Try connecting with encryption enabled.
If encryption is Required on the PLC, unencrypted connections will be rejected.
Yes, our CODESYS V3 Ethernet driver does not support encryption. Some newer PLCs require encrypted communication in order to connect. In those cases, we recommend using the OPC UA client driver in the EasyBuilder Pro project and enabling an OPC UA server on the PLC side, if available.
We have not received confirmation from our development team regarding the addition of encryption at this time. We will make note of this request and be sure to bring it up in future discussions.
