- HMI Model: SVR-100
- EasyBuilder Pro Version: 6.08.01.350
I’m having an issue where Data Sampling is off by 40-60 seconds for one of my sampling objects.
Trigger-based
Mode: OFF->On
The trigger bit comes from the PLC and I’ve added a bit-lamp to the HMI so I could check when the PLC is supplying the trigger. I’ve run it a couple of times now and the trigger appears to be working correctly. The bit-lamp and trigger address is on at the 66 second mark, which is when it’s supposed to come on, but when I check the sampled data the recording actually started 40-60 seconds prior to the trigger ever being turned on after reviewing a number of these collection events.
To be exact for one of the data sampling instances, the data sampling triggered from the control bit, then recorded a sample at 1678269099.917, but the trigger bit actually turned on at 1678269143.283
Any thoughts on where the issue might lie?
