Device No Response
Device No Response
  • HMI Model:
  • EasyBuilder Pro Version: 6.09.02
I have had this problem with many different HMI programs. I have my PLC and HMI communicating without any problem. I will make a change to the PLC offline and then download to the PLC. I import the tag database to the HMI. Once I go back online with the PLC, I get the “Device No Response” message on the screen. The only edits I have made were program based.
My two questions:
  1. How do I prevent this from happening?
  2. How do I fix the problem when it happens. The only method I have found the fixes the problem is redownloading to the HMI with the PLC online. However this is not a very solid solution. Is there certain parameters I can change to fix/prevent this problem?
