I am wondering if it is possible to add more colors to pictures when you use them. For example, I went and downloaded a picture library that I would like to use. However, some of the pictures in that library I wish had more colors/the ability to be able to change the colors. Is there anyway that I can do this??
EasyBuilder Pro Default Pictures
Hi Imersman,
Within the Picture Library, images that support color modification can be selected from the dropdown menu located at the bottom-left corner of the screen.
Please note that not all libraries include images with editable colors and our software was not designed to edit graphic images. As a workaround, you may take a screenshot of the desired icon, modify it using third-party image editing software, and then upload the edited image as a new custom library. Be sure to use the correct file format when uploading.
Let us know if you have any questions or need further assistance.
