- HMI Model: SVR-100
- EasyBuilder Pro Version: 6.08.01
- Serial Number or supplier:
I have installed a 1TB SD card in my SVR-100 but am unable to access the EM addresses. Under system parameters > Extended Memory all radio buttons are set to SD card and named default EM0 thru EM15. I have a bunch of SQL query outputs going to EM1 addresses, but none of them populate. I confirmed the issue with a basic numeric object pointing to EM7 100 address but when I download the program to the HMI and open it in CMT Viewer none of the objects are visible.
When I run the program in simulation mode straight from EBP the objects are present and everything works, it’s only when trying to access the EM addresses on the actual program.
