Help with programming a cMT2167X
  • HMI Model: cmt2167X
  • EasyBuilder Pro Version: 6.10.01
I have cmt2167x HMI on our newer production equipment and my Easybuilder pro doesn’t have cmt2167x on the model list. how can I resolve this?
Hi @myleehwa
The cMT2167X is a Weinview HMI, not Weintek. Weinview distributes products to the Chinese market, the software often requires simplified Chinese and under some circumstances a Chinese instance of Windows as well.
If you need Weinview software or support, please contact your overseas distributor or Weinview directly.
Website
http://www.weinview.cn
Beside @Aaron.S suggestion, you may contact the machine builder of your production equipment regarding this matter. The machine builder should contact Weinview for you since they purchase the CMT2167X from a Weinview distributor.
Another point is that you may need permission from your machine builder to open, modify, and access the project file. Certain machine builders set up a password or other measures to prevent users from accessing the project file that they built.
