My codesys app is running on the test bench with variables shown in the photo.
I needed to change the range on an analog input so I did that with Easy I/O and exported the revised PLC Open XML file.
Over in my Codesys app (at the Modbus TCP Master) I imported PLC Open XML. That creates ANOTHER Modbus TCP Master with no variables named to match my logic.
How can I affect this I/O change without having to recreate all my variables?
How can I change an I/O parameter within Codesys?
https://forum.weintekusa.com/uploads/db0776/optimized/1X/92ad64fee14e57f5b74a0b098b3a998b3e65cc8b_2_1024x569.jpeg
Hi @mike_c_56,
Each parameter within Easyremote IO is associated with a Modbus initialization in the “Modbus Slave Init” tab. Therefore, in order to change or update a value within the device you may:
Download the change to the module using EasyRemote IO
Update the corresponding parameter in the “Modbus Slave Init” tab:
I. Within EasyRemote, double click on the “Modbus Mapping” column of the parameter in question:
Note: Take note of the 0 base dec address, Codesys uses the 0 based address in initializations.
II. Within Codesys, open the “Modbus Slave Init” tab of the iR-ETN that you would like to update:
III. Locate the initialization value associated with this address and use the “Move up” button to move this initialization prior to row 20:
IV. Double click on the selected row and use the following popup to change the initialization value:
V. Download the Codesys application to the HMI, reboot the system, and advise if you have any additional questions.
Note: If you are using an iR-ETN and the “Modbus Slave Init” tab contains the parameters related to pulse capture and counters shown below, please delete row 6-94 as they are not needed within your application.
