- Easy Access Version 2.16.7
- Easy Builder Pro Version: 6.08.02.449
I have a language toggle switching between language 1 (english) and language 2 (spanish) using a combo button that changes the language mode (LW-9134) and LB-90 which I have linked to some visibilities and bit lamps.
This button works perfectly fine changing the language back and forth on the physical HMI screen. However, when I am using CMT viewer through easy access it does not change the language of the items in the label library, it only changes the objects tied to the LB-90.
Is there any way to have the CMT viewer be able to see the second language?
