How do you create a dynamic "Meter display" object?https://forum.weintekusa.com/uploads/db0776/original/2X/2/2a8f5840ce2dfe05092b5311e694dd8755b80570.png
I have a question regarding meter displays (gauges).
We can set the min and max value for the gauge display, is there a way we can make them adjustable?
In the application I am using it we need to adjust the MIN and max depending on a fluid running through the system. they run different types of oil so depending on the oil the limits need to be adjusted.
Happy New Year to you as well! The “Meter Display” does not support dynamic min and max without modification. I typically use a range of 0 - 100 and then associate device input with a percent along this scale. This can be accomplished using some simple macros and a custom scale. Here is a demo project that contains a “dynamic” meter display object: Link
Note: You may have to move the scale labels to ensure an accurate reading. I moved the labels “LW-11” and “LW-15” up slightly from their original position.
