I’m trying to get system time using SysTimeRTCHighResGet function from SysTimeRTC library, but getting 0 returned. How do I get local time, that I can use in the program?
How to access system time
To get the local time in your program, we recommend using the following approach:
- Use SysTimeRtcGet to retrieve the system time in DWORD format.
- Then, convert this DWORD system time to a readable date and time format (year, month, day, hour, minute, second, microsecond) using SysTimeRtcConvertUtcToDate.
- If you need to convert a date and time structure back to DWORD format, use SysTimeRtcConvertDateToUtc
For more information on HMI system times here is a resource:Demo Project
Thank you. It works with SysTimeRtcGet function.
