Within this post, we demonstrate how to change the window of your HMI project using a function key.
EasyBuilder Pro 6.06.02.233+
Instructions
Within the “Object” tab, select the function key from the “Button/Switch” section:
In the "General tab of the function key, select “Window” as the “Type”:
Next, within the “Function” drop-down list, select “Change full-screen window.” This action will close the current window and open the window selected within the “Window no.” drop-down menu:
Within the “Animation” menu, you can choose a transition animation that will run when the window changes. When pressed, a window will appear that lets you choose the animation effect, duration, and in which direction it will appear:
Place the object on your work area. When pressed, the HMI will display the window set within the “Window no.” drop-down list in this object’s settings:
Note: Use the “Label” tab to add a static or dynamic label to this object.
Keywords: function key, animations, animation, switch, select, change, changing window button, navigation, page switching, screen
