How to create a recipe report
  • HMI Model: cMT2078X
  • EasyBuilder Pro Version: V6.10.01.359
Rookie here again…
Our recipes were set up as Unicode within an ASCII property. When I select Recipe View, system tells me No Recipe Exists. Any suggestions how to create a Recipe Report from the info?
Thank you.
Pat
Hi @psimm,
Within EasyBuilder Pro, before you place the Recipe View Object, you need a Recipe Database first. This Recipe Database uses the Unicode data type, so it should fit your project.
If you already have a .db file with all of your recipes, you can simply import them, or otherwise create them manually.
Below are some resources to help you with the recipe object:
Recipe Database Basics Video
Search for filter items within a recipe database post
Please let me know if you have any questions, and thank you for contributing!
We appreciate the information. We were able to get the report generated.
