In this post, we demonstrate how to display the upper and lower entry limits within a numeric object.
Select a “Numeric” object within the “Input” section of the “Object” tab:
Within the “General” tab, define the “Read/Write” address:
Within the “Data Entry” tab, select the “Display lower and upper limits” selection box:
Note: “Display current value” will display the current value within the “Read” address.
To change the upper and lower limits of the object, navigate to the “Format” tab and update the “Device Low” and “Device High” fields:
When the “Numeric” object is selected, a window will display its “Range”. “Current Value” will also show up within the same box if “Display current value” was enabled:
