How to move an object pointer to indicate input fields in my project
  • HMI Model: cMT2166X (1920 x 1080)
  • EasyBuilder Pro Version: V6.10.01.323
    I am using a Recipe View to control parameters on a project. I am trying to use a moving object to point to the recipe field that is next to be entered. Is there a way of triggering a bit when the Recipe value is changed. The field in question is an UNICODE data type I’m not able to use the value changed trigger as I cant select this recipe field within the action trigger. Has anybody got any suggestions. I have attempted using macros to turn on bits once a field has been entered by comparing the string within the recipe to a LW address that I have data transferred the string to upon the Recipe window being opened but Im struggling to get this working too. Any suggestions would be muchly appreciated.
Thanks in advance,
Joe
Hi @MiddupJ,
Thank you for contributing to our forum. Below is a video we have on our Moving/Rotating object. Were you trying to achieve something like this: Rotating / Moving Object Video
If this doesn’t help, could you provide us with screenshots of your projects so that we may better assist you?
