Importing Schneider M340/M580 Tags into EasyBuilder Pro
  • HMI Model: cmt3072xht
  • EasyBuilder Pro Version: V6.10.01.510
Is there a tutorial that shows what the tag / address structure looks like for importing tags back into project for Schneider M340/M580 series, I currently do not have a PLC to browses to. I exported the existing addresses out of the new project to try to merry up the structure and it failed to bring in the new tags.
Hi @Andrewb ,
Thank you for your question. To clarify, could you confirm whether you’re following the steps from the Schneider M340/M580 PLC connection guide when exporting and importing the tag file?
Here is the link to the guide for your reference: link.
I was not using this guide. I was trying to export tags from interact xpress HMI, massage that data and import the tags into Easy Builder Pro software, adding to the export i created from Easy Builder Pro project.
Currently I don’t have access to the PLC. I will see if I can gain access to it soon.
Hi @Andrewb ,
With almost all symbolic drivers, the only way to import tags to your EasyBuilder Pro project is to export a tag file directly from the PLC software. Let us know if you need any further assistance with importing tags once you gain access to the PLC.
