Does easy access 2.0 and CMT Viewer work with windows 11?
Is there any known issues?
Is the EasyAccess 2.0 application compatible with Windows 11?
Hi @dsduanes,
Currently, cMT Viewer and EasyAccess 2.0 have the following system requirements:
cMT Viewer:
EasyAccess 2.0:
These applications have not been validated on Window 11, but if any issues arise you may run the application in “compatibility mode”.
Right click on the .exe or shortcut to the application in question and click “Properties”:
Select the “Compatibility” tab and enable “Run this program in compatibility mode for:” and select “Windows 7” or a different supported instance of Windows within the drop-down list:
Click “Ok” and then attempt to open the application.
