- HMI Model:
- EasyBuilder Pro Version: 06.06…
Hello,
I want to ask somebody more elite macro guy who has any experiences with account management over PLC + macro.
I need to create permanent scanning macro which will works in the two way…
First way is like - like super user over build in popup window … then I need to send register local 9220 to PLC … that works and then I now who is using the machine …
Second way is like - normal operator from array of operators which are indentified by the rfid chip and they are creating a one group … this event I need to tell HMI to change security …
When I am appling single one from solutions higher - it works but when I connected them inside the event based code - solution over HMI logging popup - not works anymore …
`unsigned int userData
unsigned int userData_old
unsigned int userFromPlc
unsigned int userFromPlc_old
unsigned int tempPlc
unsigned int tempHmi
int value = 0
GetData(userFromPlc, "Beckhoff TwinCAT PLC - Free Tag Names", "vlHMI.udtHmiScreenManagement.uiUsersStatus", 1)
GetData(tempHmi, "Beckhoff TwinCAT PLC - Free Tag Names", "vlHMI.udtHmiScreenManagement.uiUsersStatus", 1)
GetData(userData, "Local HMI", LW, 9222, 1)
DELAY(100)
GetData(tempPlc, "Local HMI", LW, 9222, 1)
DELAY(100)
if (userFromPlc <> userData) then
if (userData_old <> userData) then
DELAY(100)
SetData(userData, "Beckhoff TwinCAT PLC - Free Tag Names", "vlHMI.udtHmiScreenManagement.uiUsersStatus", 1)
DELAY(100)
DELAY(1000)
int tempp = 31
SetData(tempp, "Beckhoff TwinCAT PLC - Free Tag Names", "vlHMI.udtHmiScreenManagement.uiUsersStatus", 1)
userData_old = userData
userFromPlc_old = userData
userFromPlc = userData
else
while (tempPlc <> userFromPlc)
SetData(userFromPlc, "Local HMI", LW, 9222, 1)
wend
userFromPlc_old = userFromPlc
userData_old = userFromPlc
userData = userFromPlc
end if
end if
end macro_command`
thanks for any help
endian
