MT8106iP -ARDUINO OPTA PLC COMMUNICATION ISSUE
  • HMI Model: MT8106iP
  • EasyBuilder Pro Version: V6.10.02.284
Hello,
I am currently experiencing difficulties establishing communication between a Weintek MT8106iP HMI and an Arduino Opta WiFi PLC (model AFX00006). I am using the Modbus TCP/IP protocol to read and write data between the two devices; however, the HMI does not appear to receive any data from the PLC.
Both devices are configured with valid IP addresses on the same network, and basic connectivity (ping) is confirmed. Despite this, the HMI is unable to read the PLC’s Modbus registers.
If anyone has encountered a similar issue or can point out what I may be missing in the configuration, I would greatly appreciate your guidance. I am happy to provide additional details or screenshots of the setup if needed.
Thank you in advance for your assistance.
Noli Valdez
Hi @Noli-Valdez ,
Thank you for contributing to our forum!
Could you please share some screen shots of your device settings within the system parameters? Also, would you advise the IP address of the Opta and HMI?
If you hadn’t had the chance to review our YouTube channel, here are some helpful tutorials on how to connect an Arduino Opta and Weintek HMI:
Weintek’s Codesys to Arduino Opta via Modbus RTU
Weintek HMI to Arduino Opta PLC using Modbus TCP/IP
