MT8106IP Energy A analyzing and logging Data
  • HMI Model: MT8106IP
  • EasyBuilder Pro Version: 6.09
Hi Experts
I have MT8106IP hmi FICO Energy Analyzer and DELTA Plc. I am reading multiple registers in plc by using modbus. Plc and hmi connected on com2. Now i have multiple data in different registers. Now i want to display on HMI. Logging and saving different values. Save in excel format. Then i want to see all these data on cloud by weincloud and easy access. Guide me how to save data. How to uses weincloud. How to use easy access. I need details
Good evening! Sharing a little of what I’ve already done:
1- Easy Access 2.0 is remote access, it requires a license, it entitles you to 20 tags without history to create a project in WeinCloud.
2- WeinCloud, a cloud platform, if you have more than 20 tags or history tags, you need an extra WeinCloud license.
3- If you managed to map the addresses correctly using EBPRO, it will depend on what exactly you are going to do: history, data sampling… there isn’t just one way, you need to configure whether you will save to a database, FTP, internal memory…
4- After deciding what to use, there is an object that backs up in CSV triggered by some event (button, macro, JS…).
5- In WeinCloud you need to create an account on the Weintek website, create the project in the cloud, create tags. In EBPRO you need to synchronize the tags you want to use. If everything goes well, it will appear online on the website and publish.
Hi @engrmunir786,
Thank you for your question.
Adding on to @eddy_neves, to display your data we recommend using ASCII Objects or Numeric Objects tied to your memory registers. For logging and saving data to Excel, we recommend using a Data Sampling object to log the memory registers you want. You can then use a Backup object to export the Data Sampling data as a CSV file, which can be opened directly in Excel. This also allows you to display the logged data using Trend Displays or Table objects on the HMI.
For Weincloud and EasyAccess setup, I’ve linked a Weincloud introduction video below.
Please let us know if you have any other questions.
Data Sampling Object
Numeric Object
Weincloud Introduction
Hi Experts
first of all thanks for your replies. i am replying on both responses. i received HMI Model TK8072IP. i have three FICO Energy Analyzer. i interface all of them on Modbus by using Delta DVP PLC. all Three Energy analyzer interface on RS485(Modbus). I can Read and write energy analyzer regiesters. now i make a program for my TK8072IP HMI. in which i am using Data Sampling. i have around 6 registers for each anlayzer to read. in which one register(KWh) from each analyzer will be displayed on Trend Display on daily basis.i have to display daily data and also save daily data on USB. the daily KWh consumption must be monitored online and also make a log for around 2 months data. if user want to see the specific date data then he can monitor and view the log files easily. now can you please tell me how i start this project in a professional way. i have to take easy access license.(OK) but my question is that only easy access license will enough for my requirements like data log and monitoring. actually there are three source. 1- GRID 2- SOLAR 3- GENERATOR. my task is to monitor daily usage from all these source in form of KWh(Kilo Watt hour) and make a trend display and log in a separate file as well as online view and see log files.
Hi @engrmunir786
The TK8072IP is a Weinview HMI, not Weintek. Weinview distributes products to the Chinese market, the software often requires simplified Chinese and under some circumstances a Chinese instance of Windows as well.
You will need to confirm with Weinview for the most accurate answers regarding how to set up the TK8072IP project. Below is the website to contact Weinview.
Website
http://www.weinview.cn
