- HMI Model: CMT3162x
- EasyBuilder Pro Version: 6.08.01
- Serial Number or supplier: WESCO
Is it possible to print all of the screens/windows in the window tree to a single PDF file all at once? Or even select a group of windows/screens to print to PDF file?
It is impossible to print all of screens/windows to a single PDF file at once. A screenshot will be saved in .png picture file.
In my opinion, a workaround is to utilize a PLC Control object (with Screen hardcopy selected within the Attribute).
This way during runtime you can dynamically select a window/screen to print to a .png file, save it in the same folder, and save it by date/hr/min/sec or give a name that you want.
It is possible to automate the screenshot process in sequence by writing a macro.
Hi @rogaroga,
If you would like to print the project windows so that you can create a manual for your customer or for your reference, you can print the project windows to a PDF using the following method:
- Within the “File” tab, click “Print”:
- Within the following menu, ensure that “Microsoft Print to PDF” is selected:
- Follow the prompts to save the PDF to your PC.
Thanks, that’s what I was looking for, and for that exact reason (binder for customer, clips for manuals, etc). Once I set the option to “shrink to fit” all was great. Thanks again.
