- HMI Model: cMT3162X (V2)
- EasyBuilder Pro Version: 6.09.02.451
Is there a limitation to the number of tags/the amount of data that can be brought into EasyBuilder in a single “Import Tags”?
I am using the Siemens S7-300/ET200S (Ethernet) driver and when I try to import my .dif file, one of my DB’s has an error. This DB is an array of 3599 integers, which is why I’m curious if there is a limit to the number of tag that can be brought in with a singe import or if there is a limit to the length of arrays that are being imported.
