- HMI Model: cMT2108X2
- EasyBuilder Pro Version: 6.09.01.357
- Serial Number or supplier:
Good morning,
I have several graphic (simple filled circles) and Numeric objects on a window in my application. On the Security tab of each object, Enable/Disable are all set to the same boolean PLC tag, some set to enable when on, some when off, and all to hide when disabled. PLC is CODESYS running in the same cMT2108X2.
When I run my application and change the state of the control tag, the circles appear and disappear as expected, but all of the Numerics remain onscreen regardless of the tag state. Am I missing something? Thanks for your help.
–Mike
