- HMI Model: cMT-FHDX-820
- EasyBuilder Pro Version: V6.08.02.449
- Serial Number or supplier: 2305105943
I am currently trying to transfer images to the usb disk connected to the headless hmi using the ftp function from the IV series Keyence Cameras. However every time i try and transfer to the usbdisk via the ftp, the camera says failed to transfer. I have it to where the HMI FTP is able to access and modify what is on the usb disk since I thought that was the issue. I know I am able to transfer stuff successfully and connect to the hmi If i change the folder location, as it just makes a new folder location on the hmi ftp and transfers the Images completely fine. Im just seeming to have a issue transferring it to the USB Stick connected to the Headless HMI.
I feel as though I am missing something very simple. Any advice or help would be greatly appreciated!
Edit: I solved the issue, seems to have been the usb stick was not formatted correctly, Got a new usb stick and it transfers it no problem now.
