- HMI Model: cMT3071
- EasyBuilder Pro Version:V6.09
- Serial Number or supplier: 2003100574
After I downloaded my project to the cMT, the HMI reboots, but the display comes back to the “cMT Series” splash screen. It does not run the downloaded project.
Everything looks correct on the download - connects, downloads, extracts, reboots, finished.
My startup window is set to “10” in System Parameters.
Hi @JBeckmann,
Prior to downloading this application, did you enable “Runtime”?
If possible, can you please re-enable runtime or ensure that “Runtime” is enabled and re-download this project?
When you have a moment, can you please advise what version of EB Pro 6.09+ you are using?
Also, can you please advise the HMI’s OS version for my reference?
- Select the orange settings button located in the top left corner of the HMI:
- Select the “Information” tab:
My EBpro version is:
And the OS is 20191001
Note: For anyone else that may have questions related to this topic, here is the result of our findings.
The issue may be resolved by upgrading from 6.09.01.605 to 6.09.02.338+. In the event that your HMI does not seem to complete the ‘reboot’ sequence and displays a variation of the following screen:
please upgrade to the latest version of EasyBuilder Pro, re-compile, and re-download your project to the device.
