Adding language to existing project
Hello @AAHBEARS,
Thank you for contributing to our community. To add a language to your existing project, please review the instructions within this post: Link. Also, please note that the fastest way to add new labels to your project is as follows:
  1. Double-click an object to open the object properties menu. Within this menu, select the “Label” or “Font” tab:
  2. Assuming the object has an existing label, click the “Add to label tag library” button:
  3. Within the popup window, choose the label tag name and click “OK”:
  4. Select the “Label tag Library…” button:
  5. Click the “Settings…” button or use type directly within the “Lanuage 2” or Language _" option to enter a new translation:
  6. To use the new ‘language’, follow the instructions within the tutorial mentioned above.
