Connecting to remote Codesys PLC via OpenVPN
I’m trying to connect to Codesys running on CMT2078X.
OpenVPN creates a Virtual IP address for each device on the Network. When trying to add device with this virtual address via UDP/IP Codesys does not accept it saying there is no route to this address, when using TCP/IP it just scanning the network and does not add device.
TAP adapter is running and I can access other device on the network
Hi vladmen,
Thank you for your question. What LAN port are you using to connect your OpenVPN to Codesys.
-Aaron
Both ports on HMI are connected to the local Ethernet switch, which is connected to VPN device.
Could you try running a ping test to verify if the IP address you’re trying to reach is currently active and responding?
Yes, I can ping it via virtual IP address
That is good to hear. Next you provide me the Codesys version you are using and a picture of your Codsys IDE like the example below:
Codesys V3.5 SP15 Patch5 + (64-bit)
Getting an error when trying to attach image to the post
Could you uploading one more time.
Here are a couple more images to illustrate my setup
Can you try the following:
  1. Please enter the virtual IP address directly into the drop-down menu to establish the connection.
  2. Could you also enable Codesys login as in this post: How to enable Codesys login
Also one more question. Is the virtual IP at 10.16.32.20 routed through LAN1 or LAN2?
That did it.
Thank you so much for your support.
