EasyAccess for iP series
I am unclear if EasyAccess2.0 is available for the iP series HMIs. I have an MT8072iP.
I understand that this will require the HMI-Viewer. Also I will need to purchase an EasyAccess Activation card/code. Do these work for the iP series??
Please clarify what is possible.
After purchase of an Activation card/code are there any further costs to use EasyAccess?
To activate EasyAccess do I need to be at the HMI?
Hi @BrianF_NZ,
EasyAccess 2.0 is available for the iP series of HMIs. To activate EasyAccess 2.0 on your HMI, you will need to purchase an activation card. After the purchase, there are no further costs associated; once activated, it will remain active. For the activation, the HMI will need to be online so that the hardware key of the specific HMI can be read.
Below is more information on EasyAccess 2.0 if needed.
New to Easy Access
More
Thank you. Would you please clarify/confirm some additional points.
I understand that EasyAccess is linked/bound to a specific HMI panel as part of a Weincloud domain. Furthermore, multiple users (each with their own password) can be assigned to the domain and to the HMI. Correct?
Is there any limit on the number of users who can join the domain and be assigned to the HMI panel?
In my case there will be just a single HMI linked to the domain, but potentially 3 or 4 different users.
Once set up initially, can the domain admin role be reassigned to a different user - eg if the admin-user individual leaves the organisation?
Hi @BrianF_NZ ,
Yes, you can add multiple users to your EasyAccess account under the same domain email. EasyAccess supports a large number of users within a single domain, and everything will function normally.
Regarding the admin role, you can either change the email associated with the existing admin account or assign the user a Super User role, which provides nearly the same level of access as an admin.
