How do I troubleshoot "Error code: 102"?
Hi,
I activated one of my HMI’s through EasyAccess 2.0, used one of the activation cards recently purchased , it said HMI was activated successfully and even appears offline.
So I go to the HMI’s settings>EasyAccess2.0>Activation and I press the detect button and I keep getting this error .
Unknown error
(Error code:102)
Any idea?
Thanks
What HMI model are you using?
If your HMI is equipped with dual ethernet ports and Codesys is not activated, LAN1 port must be connected to a router to access the internet.
LAN2 port doesn’t support WAN (Wide Area Network)
HMI model:
CMT3072x
I have it connected to LAN1
I fixed it, thanks !!
