Hello there
Completely new to Codesys and Weintek.
I have a CMT2078X and an IR-ETN40P that I want to set up using Codesys.
I have downloaded the recommended version of Codesys together with the Easy Remote IO and EBPro.
When I start my Codesys project and select the Weintek Codesys option I get over 60 errors for missing items etc and I am pretty stuck there.
Is there a process I need to follow to set this up as we are keen to move forward with Weintek as it suits all our current requirements.
Hi @TonyWells ,
Does your Library Manager have a ‘Download Missing Libraries’ button? If so, please keep installing the missing libraries until that button is no longer available.
If the issue persists, could you try the instructions in the post below?
Thank you.
When opening a CODESYS project, you may see a “missing library” error if the Weintek CODESYS Library is not installed on your PC. This post walks through how to install the Weintek CODESYS package and then reload your project so the missing library error is cleared.
CODESYS: 3.5.15.50
Install Weintek’s CODESYS package
Close the current project that is throwing the missing library error.
[File] > [Close Project]
[image]
Download the Weintek …
As I said completely new to Codesys, missing libraries button worked a treat, many thanks for quick assist
Hi @TonyWells ,
Glad to hear that worked!
