After migrating an EasyBuilder Pro project from an iP, iE, eMT, XE, or mTV series to a cMT series HMI, you may experience unexpected behavior. Below, you will find links to posts and documents that help resolve common issues that occur during project migration.
Instructions & Documents:
In EasyBuilder Pro, migration from your existing eMT/iE/XE/iP project (.emtp) to a cMT series project (.cmtp) is feasible using the HMI model selection list within the “System Parameter Settings.”
Once the HMI model is converted to a cMT series HMI, you will receive a list of warning and error messages in a popup dialog called “project migration report.” The resources below will help you resolve these warnings/errors.
Related Tutorials:
Project Migration: non-cMT to cMT series HMI
The general steps to convert your existing project are summarized as follows:
- Compress your existing .emtp project in your old version of Easybuilder Pro.
- Uncompress your project in the latest version of Easybuilder Pro.
- Select the correct cMT HMI model from the HMI selection list within the “System Parameter Settings.” EasyBuilder Pro will handle the conversion of one project file to another.
- Look at the warning/error messages in the “project migration report” dialog.
- Understand the differences between the eMT/iE/XE/iP HMI and the cMT X HMI.
- Resolve compilation warnings and errors. Ensure each feature is migrated in a manner that ensures near original functionality.
- Validate the cMT X project.
| UAC-related | Object-related | Compilation Issues | Docs |
| Login Issues | Keypad Issues | Error/Warning Resolution | Notes on Project Migration |
| Overlapping Object Issues |
migrating, migration, login, log in, uac, keypad, keyboard, overlap, overlapping, issue, issues, error, warning, compile, compilation
